TwinTurbo.NET: Nissan 300ZX forum - Before replacing
Subject Before replacing
Posted by Broke_as_**** on August 01, 2013 at 11:47 PM
  This message has been viewed 325 times.
In Reply To Re: Have you done a boost leak test? posted by Hydrus (Dallas) on August 01, 2013 at 10:58 PM
Message I would try swapping it with another hole, coil, plug and injector, if you haven't already. Also, try searching your area for an injector specialist, they can usually do a clean/inspection on an injector for ~$20 each, might be able to tell you what's going on. I can understand not wanting to spend the twenty when you're already counting buying a new injector but I usually figure it's best to know for sure before spending the bigger wad on new parts.
